Suggestions on Spark Plugs & spark plug wire holders?
DartThis74
Houston,Tx
I was curious what is a great spark plug for my 360. It is a mild built engine putting out 285 hp on the dyno. Also, does anyone have any good suggestions on wire management for the spark plugs, like stand offs,etc... that have worked well for you using headers ? Thanks in advance !!
-Aaron
In my opinion the best spark plug wire seperators at any price is the one from Spectre. They're $22.09 at Jegs right now. We've been able to adapt them to fit every application we've had.
http://www.jegs.com/p/Spectre/Spectre-Wire-Looms/758074/10002/-1?itemPerPage=90&pno=1
1974 'Cuda 340
Supercharged 512 stroker
1967 Barracuda 318
1967 Barracuda 408 stroker
1968 Chevelle 396
1972 Duster 440 without separators
1972 Duster 440 WITH separators
Thanks for the info! I was curious would could be used with the Mopar performance valve covers. From your pictures looks like it works just fine.
RN12YC or RN14YC will probably work just fine.
Here is another option for wire looms/holders. Very convenient and affordable. You can anchor them onto most anything once grouped together.
That's a cool idea Rob. Do you have more pictures of that from different angles so I can see how they wrapped them? It's hard to tell from that one angle...
It's just one zip tie around three plug wires separated by two other zip ties. Nuthin to it. I had just done my new wires like that on my Ranger right before it got totaled.
