Summit Code
Depending on how much you spend, Jegs has a better deal that Summit will match.
Yes, the october that just ended was a little better. I think it was 5.00 better at each break. Each code appears to last a couple weeks, before they change it for another you just have to time it right. More or less the codes now off set the tax and that’s about it. Swingn’.......
Thank you sir
So is the lowest amount $ 250 to get anything off always ? Didn’t know if they had 5 or 10 percent off any amount. Haven’t used a promo with them before. Thanks
Yep, looks like 20. Off 250 40. Off 500. 100. Off 1200. I think that is the most current. I am on the email list so I just watch around the time I am building an order up. ‘Save100’ is the current. Swingn’
