Sun Visor Installation
Remove rubber tip.
Rotate rod in old unit while pulling rod out.
Reinsert rod in new one.
Replace rubber tip.
Install 3 screws to replace assembled unit in car.
Repeat for other side.
Remove rubber tip.
Replace rubber tip.
Thanks a bunch man. I wasn't sure if the support inside the visor was supposed to be transferred over in addition to the rod.
I'm going through a similar issue, it seems the rod on the passenger side is @ 1/4" short to reach the rear view mirror. Any suggestions?
Thanks
Alan, That seemed to do the trick. I did not know that the rods were adjustable,Thanks again.
Tom
The key is that the rod is two pieces, this is a 69 C-Body but the same idea.
Alan
