Craig Smith
1966 Valiant 200, Super 225
The heat riser on my 1966 Valiant is totally stuck, though I've been able to wrench the flap all the way vertical, and the car runs fine, but the temp gauge (installed by PO) runs up to about 230-240 degrees. When I pull over and open the radiator cover (very carefully) the coolant has no boil over and the cap isn't even very hot. Either I'm getting a false reading or I suspect this is because the riser flap is stuck vertically. I had to pull the manifolds, so I tried to move the riser flap again. It came loose from the mounting pin so put it back this time with the flap immobilized in the horizontal position. Now the car runs fine but at about 155 degrees. I won't be driving the Valiant in the winter so I'm not concerned about warmup time, but I am wondering what the long term effects could be driving with a riser flap stuck horizontally . Any thoughts?
