[SOLD] Sway Bar, Lt. Side UCA, Disc Brake Spindle, Dust Shield, 73-76 Cars.
hemi71x
hemi71x
Rancho Cordova, CA
I have some parts from the 73-76 A Body line of cars, up for sale.
If you have some damaged, bent, parts, i may have what your looking for.
1. Factory Front Sway Bar, and mounting brackets to the crossmember, and the end links to the lower control arm.
You will need new rubber bushings for the bar, and end links, but all the hardware is there.
$100.00 for everything.
2. LEFT Side Upper Control Arm. Big Ball joint UCA, with the old, shot, bushings removed. The ball joint is pretty tight, so you may want to use it, "as is". Your call on that.
Cleaned up, and soaked off in a pail of Evaporust, to bring it back to bare metal condition.
$70.00
3. Left Side DISC Brake spindle, with all the bearings and seals. Nuts & bolts.
$95.00
4. LEFT Side gravel shield, for the spindle. Not smashed, dented in. All cleaned up.
$20.00
Smaller parts i can mail out in USPS flat rate boxes, but the sway bar and hardware will be by FEDEX, and i will need your zip code to give you a quote.
Payment will be thru Pay Pal, with their fees included.
Serious people, send me a message and i will get back to you with all my payment information.
Thank's a lot.
Jim V.
hemi71x
