[WANTED] swinger b-pillar patches
forced 340
michigan
hey guys. im sure its a long shot, but is there any b-pillar patches out there for a swinger?
good to know! its hard to tell by the pic, but is that the outer part or the gutter? sorry, im not to familiar with body panel names.
are you looking for new or used patch panels? you would have to relead the leaded joint in the pillar at the base where it meets quarter panel. plus there is bracing in the interior and in the trunk in that area going to the wheel house that contains the torsion bar springs for the trunk lid. you need to really get a good look inside and out. looks like rust from a vinyl top, best if you strip the whole top of the car to make sure you know what you actually need
looks like it could be repaired with regular sheet stock or a panel cut from a parts car roof or a hood or trunk lid.
could also be repaired with lead.
used cut from a car would be great! the bracing and everything else looks to be ok. it really just needs some sheet stock which I can make, but a piece cut from a car would be better.
I have top parts of NOS drivers 4 door quypanels. The red primer one is cut at the top body line. The gray is cut off at lower body line. In CT, prefer p/u
thanks, but I don't think 4 door parts would work?? isn't the windshields at diff. angles?
