switch pistol grip to white ball
ereru7
Member
i want to get rid of the pistol grip and have the white ball. just get the white ball handle? is thatr all?
You need to replace the entire shifter. A ball wont screw on to the pistol grio handle.
Why would you want to take out the pistol grip? But if oyu do you will need the handle too. Plus you will need to know what shifter you have as to if it is a 2 bolt type or the slip in type
Is the shifter a bolt in or slip style. 72 chally should be a bolt in.
I'm looking for a pistol grip shifter. Want to sell it or trade for a standard style shift handle, let me know.
if its a bolt in handle,,you just need to find a handle you like,,that will be in the correct position and get a ball,, you do not need to change the shifter,, only the handle,, this can be done from inside the car under the boot and or console if equiped. if it is a slip in handle and you want to take out the pistol grip,,i believe you will need to find a shifter that has a bolt in handle set up,,, i have never seen a non pistol grip arm thats is a slip in,,
