t fitting on rear end
I've seen these somewhere before. Maybe thru one of the outfits like SSBC or so.
Another option would be to look into getting a later model A body rear brake hose like a 73, these have the brass tee built in as part of the hose assembly. Make sure the hose length is long enough and you should be good to go.
