Oct 5, 2024 #1 andysauto1 FABO Gold Member FABO Gold Member Joined Nov 9, 2022 Messages 513 Reaction score 1,127 Location Flora, Il. 1972 340 Demon taillight problem, all three wires show to be hot on both taillights. Changed rear harness, same problem, fuses all ok. I'm sure it is something simple, just not good at electrical trouble shooting.
Oct 5, 2024 #2 Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member Joined Jul 16, 2017 Messages 19,229 Reaction score 16,625 Location Northern Colorado Ground from bulb socket to chassis?
Oct 5, 2024 #3 andysauto1 FABO Gold Member FABO Gold Member Joined Nov 9, 2022 Messages 513 Reaction score 1,127 Location Flora, Il. Yes
Oct 5, 2024 #4 Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member Joined Jul 16, 2017 Messages 19,229 Reaction score 16,625 Location Northern Colorado Measuring voltage with a volt meter can show battery voltage where there is a really bad connection in the path. Get a tail light bulb and add a wire to the base and to one of the contact points. A bulb socket makes this easier Then put it in the cir like if it was the volt meter. If the light doesn't light then it indicates a bad connection, They make test lights that do the same but a bulb and wires work in a pinch
Oct 6, 2024 #5 andysauto1 FABO Gold Member FABO Gold Member Joined Nov 9, 2022 Messages 513 Reaction score 1,127 Location Flora, Il. Problem solved, ground wire inside dash hacked, made new ground now every thing works
