TBI for 1973 Dodge Sportsman B30 in Canada?
zit
New Member
Winnipeg
I'm looking for like this, but available in Canada (Winnipeg)
MOPAR / CHRYSLER Legacy Complete TBI Kit
Please select your engine from the drop down list below:
MOPAR 5.9L 360ci V-8
Please select your transmission from the drop down list below:
Torque flight 727/999 Automatic
Distributor options: Include ECM controlled distributor (recommended) ($200.00)
Would you like a new coil and primary ignition wires?: yes ($59.00)
Options: $334.00
Please select your desired harness length: 30"
Please select the appropriate intake adapter plate:
2 jet 2 barrel (bolt pattern) 3.75"x 2" ($75.00)
Would you like a fuel pump?: yes
Options: $334.00
Please leave any comments or specifics here that will help us make your product a better fit!:
It is a 1973 Dodge Sportsman B30 vin B30BF3V053273 Balboa
Engine Casting number 3418496.5.360 (the zero looks like a C)
1971-1974, 360 LA-series small-block
Holly carb 12R-4761B 2bbl (can't get it to idle. tried several times
Why don’t u just buy that kit? I have a 88 truck for parts if u need fuel lines and stuff. It was a running truck 10 years ago. I took the tb off of it to put on my 89 truck instead of changing some sensors. Kim
Would have it delivered to Fargo, and drive down to get it if it weren't for the Covid restrictions.
I had tried and failed to order.
Contacted the company, and they are willing to ship to Canada for $120 shipping.
Now ordered :-)
