[SOLD] TCI 727 Transmission Shield
Rocket
CT
TCI automatic transmission shield for 727. Part # 910000. SFI approved. Date stamp is February 1993 so you will need to check rule book if your track checks for specific dates. Only used 30 runs on my bracket car. It is in great shape and in storage for past 15 years. Comes with attaching brackets and hardware (not pictured).
Good insurance for protecting your feet from potential drum explosions.
$100 shipped in the U.S.
I've never run one of these shields before. Where are the attachment points? Does it work with both big and small block 727s? Are there any clearance issues with firewall/transmission tunnel?
I had this installed in a 1970 4 speed Dart with a small block. I had no clearance issues myself. It is a tight fit however with the floor. The 2 pieces attach on each side with an angled adapter bracket which bolts to the transmission oil pan bolt holes. The adapter plate and hardware are not shown in the picture but come with the shield. As long as the transmission is in the same place with the big block, which I believe it is then you should be fine.
