that time of year again
diymirage
HP@idle > hondaHP@redline
michigan
i put new tires on the duster (small bolt pattern with small studs and alluminum slots) and wouldnt you know it...i forgot to check the torque before pulling them off
i put them at 80 pounds right now, sound right?
steel wheels vs aluminum wheels = different torque specs. steel is 80-85 and aluminum is 70, generally speaking on both. Also, don't forget to do it progressively.. star pattern and work up from "hand/wrench tight".
You don't want to overtighten those 7/16 studs. I agree 70 ft/lbs is more than enough with the aluminum wheels.
thanks guys
ever since i lost a aluminum wheel on the bronco, im a little bit hesitant on "good enough"
ill keep them on 80 for now
next time they come off i will put it at 70
(i did do the star pattern)
FSMs are such nice things.
unless you are looking to replace your studs!
