The same or not
Frank Dinatally
Pennsylvania
I am sure someone knows
I have a 68 Fury that has a 360 LA motor in it. The exhaust manifolds are from the 318 that was in it. One of those has a broken flange after 10 years. Question is wil used from 318 or 273 or 360 fit for me to put on?
Thank you as always
Get the casting number from it and find a duplicate so your pipe will bolt up to it.
Where the exhaust manifold bolts to the rest of the exhaust system can vary in location, angle & size, depending on engine, year and original body it was in. The resto people may have more details on which castings may interchange. If there is a casting number, you can post an ad for that specific part.
so 273 and 318 will not interchange 2465769
I don't know much about casting numbers....and the 318 might even have the small ports. Some of these other guys will know for sure. I would stick with 340/360 port size manifolds at least.
Found this little tibbit Now am really confused
318 are smaller port but if it's a stock 360 not the biggest issue.
