Thermostat housing Street Dominator
Righty
Bristol UK
I’m going to replace the thermostat on my Barracuda, the intake is a small block Street Dominator on a 318. A bit of a lazy question but to save having to disassemble the housing to measure and then wait for the part to get here from the US does anyone with this intake know the thermostat housing size? Thanks.
I donot have the dimensions but I bet Holley does on their website.
I thought I read an arrival years back that they used a Chevrolet small block housing size.
I've tried a fair bit of searching on the Holley website but couldn't find anything on the intake, would help if I had a part number, but even putting in the numbers from similar intakes doesnt seam to produce any results. I'll keep searching.
Standard thermostat for your year and engine. Same for the thermostat housing.
Yep, it took me an hour or so, but I got there in the end. Kind of common sense I guess, the radiator inlet is standard for the year, so the outlet from the manifold .is going to be the same.
