Throttle bracket
Strokedcuda67
Member
Southern ohio
can anyone tell me the part numbers for the lokar bracket and kick down cable
I have a 340/727 a body with the air gap and edlebrock carb.
Also can I use my stock throttle cable or do I have to use the Lokar
I'm using stock throttle cable. Demon carb one inch spacer and airgap clone
AR Engineering sells a really nice bracket for stock throttle and Lokar k/d cables.
You can use your throttle cable, but you may need a new throttle bracket for a 4 bbl.. Cable has to be moved forward to work carb fully. Also you will need kick down linkage for the new arrangement and that's were most guys use the Lokar kick down linkage. I did this conversion about a year ago. Very satisfied with the operation now. I did buy the 4 bbbl. throttle bracket and the Lokar kick down cable.
