Throttle Cable Bracket Help
djwhog
I need Throttle Cable Bracket mounting help. I have an early Dart and I replaced my LD340 intake with an Air Gap Intake. Well it does not have the threaded 5/16 bolt hole next to cyl runner #5. The Dart has a small little bracket that has a single bolt to hold it to the intake.
I also have a 78 truck with a 360. I noticed it has a type of bracket that goes to the intake bolts runners 5-7 stradled. Looks like that type may work, but I think the runners on the intake of the Air Gap are too high and will hit the bracket.
So what are you guys using to mount your cable on this intake on a small lock?
thanks.. and if someone has one that works for sale PM me please.
thanks
Dave
I bought an adjustable one for the high rise intake, fits like a glove and works nice! I got it off of ebay, I can take a better picture if you want!
I have the same bracket as Keith. I had to clearance the inside edge where it made contact with my manifold, but other than that (and modifing the mount for the cable because everything about my 6 Bbl. is a pain in the...) it works great.
