Throttle cable into firewall
Plumcrazyfreak
MN
Any suggestions would help. New Lokar throttle cable installed. Car ran great for a couple days, then carb wouldnt idle down. Found the fitting at the firewall very loose. What is the proper way to mount the fitting to the fire wall ? The firewall opening seems sloppy. I tightened it and the carb still wont idle down because the throttle wont return completely.
Fishy hit the nail on the head. Fender washers..... alos make sure to shoot a bunch of spray silicone from the top down inside the housing so the cable slides free.
