As I read the thread about the broken hinge it occurred to me that maybe I should lube the hinges on my wife's convert. Looking at it closely I can see a little bit of rust at each joint. It goes up and down but maybe a little lube might make it work a bit better, what do you guys use to lube to pivot points? Thanks, RH
