Okay so I'm gonna ask a question that sounds dumb at least to me. I'm having a hard time wrapping my head around the issue.
The setup: So I have what I consider a mild built motor in my D100. 318/396 stroker, speedmaster heads, port matched Edelbrock single plane intake, Holley Sniper 2, comp cams mild cam 20-222, and long tube header and full custom exhaust. The motor runs really well. Its backed by a rebuilt 46RH with a stock replacement converter and it had a 8.25" & 3.23 gear with 20x8 wheels 31" tall... With all this the truck was strong but the gear felt lazy off the line, so I swapped out the 3.23 for a 3.91. YES! now this truck runs exactly how I've wanted for a while. Good punch of the line power band in the right spot for each gear cruising at round 2500rpm at highway speeds.
The Problem: Coming up to a light if I slow down to fast I can feel the motor struggle and then it stalls.....?WTF? If I slow early and I allow the trans to down shift as on its own as I pull up the motor still struggles a but will recover and idle. If I roll up at normal speed and shift into neutral before stopping no issue, unless I'm really going fast. My first thought was my lockup converter was still engaged and causing the issue so I disconnected the lockup and still have the issue... also I noticed when starting the motor if I toss too fast into gear forward or reverse it will also stall... I'm at a loss... "Also I have manual brakes so its not pulling a vacuum"
The Question: Could the stock stall converter be stalling out my motor? -This sounds so dumb to me-
