torque converter identifacation
hamesdart
souther cali
so i ripped my motor and trans out and opened everything up
never new what i had but i finnally get to see.
i need help identifiyng it,
looks like 10" TCI
numbers on it read 1430
10376r and on the teeth part of it says o69j
any help would be appretiated i need to get info on stall speeds and whatnot advertised.
727 PRO-X™ Torque Converter 9" Steel Stator W250+
PART #143010
$1,579.32
Quantity:
None in your basket
DESCRIPTION:
The TCI® PRO-X™ 9 & 10-Inch Race Converters are designed specifically for Top Sportsman, Top Dragster and Outlaw Street Car classes. Able to handle 2500 hp plus applications (including multi-stage, nitrous assisted, supercharged and twin turbocharged engines), these high strength torque converters feature a TCI® exclusive - HDT Coating™ (Heat Dissipating Technology™) - further enhancing their ability to deliver unsurpassed consistency and durability.
* Hand-built steel stator
* Forged mounting cover
* 3 sets of heavy-duty internal bearings
* Furnaced-brazed turbine and pump assembly
* Built for GM, Ford and Chrysler transmissions; six or four-bolt flanges and optional billet front available
Click here for contact information.
You may also seek a recommendation by filling out our online form.
two questions did it say a stall speed?
and how did you know that its the 143010
and not another one? was the 10 at the end from the start of the other number i gave you?
thanks
