Toyota truck rims?
gremlin
268Darts
Houston
I looked at a set of 14x7 rims w/4.5 B.S and was about to load them up when I decided to check the hole circle. It measured real close so I asked what the rims were off of. The ad said 4.5 hole circle. Toyota truck was the answer. Anybody know if they would fit.
Yes, 'Yota 5 hole is the same as Mopar and Ford car. If they are stock 'Yoda rims check the center hole to make sure it is big enough. If they are aftermarket wheels I would bet the center hole is big enough.
Later Mazda truck also fits but it is basically a re-badged Ranger.
Chuck
Well I picked 'em up and they fit great. I noticed they say max. tire size is 28" and max. load 1850 lbs. Now all I need is some tires.
