Traction options
69fishy
St Augustine fl
need a little help with my hunt for more traction. Currently have an 8.8 with 3:55 gears withOUT limited slip. Two options I see. Install a lunchbox type locker in current rear end. or swap in a new 8.8 with 3:73 and limited slip. I am tired of the one wheel spin.
Would the increase in cruise rpm be worth the extra gearing and traction???
Set up as follows.
69 barracuda, 383/727 with 27" tires.
You would probably barely notice the difference between those two ratio's as far as cruise RPM's, but you would get your limited slip.
