66Dart225
Active Member
I have a 66 dart. 225. I want to use a universal cooler all the ones I have seen come with rubber lines. My question is isn't the lines under pressure. Won't the rubber line just break.
Put the rubber lines on over a flare if you can, because it makes it a lot harder to blow a line off as the rubber settles under the clamps and gets looser.
