trans dapt 4698 SB K to BB motor mount
clementine
Flight risk
Emerald city
alright alright alright....mocking up this small block K frame (67 barracuda 383 4 sp) with trans dapt 4698 mounts (sb K to BB) and its going pretty good, but I'm wondering if i need a different oil filter bracket? Or.....push engine forward a smidge...(only have 1/2" until fan pulley hits.) Or shim.... (was hoping to avoid major shimming, one of the reasons to try the swap from previous K)...or cutomize either the mount or the K member. If customizing the K/ mount is your choice, please include measures you would take to make sure engine is in car in the right spot (stick location, shifter rod location, Pittman, idler.... yknow stuff like that so i don't mis anything)
Thanks FABO
Ill cut it in the morning. those buscuits seem awefully thin, I dont see the steering gear clearing those TTI's. I know they are supposed to fit.....Ill find that chart again that tells me where the BB is supposed to be to clear everything. If Im modifying chit I might as well modify all of it. besides this suspension stuff glass/interior Its pretty much a runner......so .....another two years?:rofl:
