Trouble Lining up Power Steering Pump With Harmonic Balacer.
MAGA
Member
Oregon
I just put in my rebuilt engine that has a new harmonic balancer and water pump. Now My Power steering pump doesn’t line up with the rest of the pulleys.
The fan belt pulley on the water pump lines up with the outer ring of the harmonic balancer and the alternator, but the power steering pump is extended far outside all other pulleys!
What is best solution?
Do you have a 3 groove lower pulley laying around to try?
A slant has a bolt on pulley that goes on the front of the damper for power steering and one that goes on the rear of the damper for A/C. You may want to post a wanted ad for one.
