pastortom1
Not sure where to post this.........Had a senior moment I guess.......I removed and anodized the trunk lock mechanism that bolts up inside the trunk................
As I was putting it back in, and adjusting it to close properly, I found the right spot and it latched........problem is, the lock rod is not in it's slot.
SO, I can't get back in the trunk.
I'd go in from the back seat and turn the lock, BUT there is a 3/4 plywood wall there that can't be removed from the back seat.........I need to remove the lock from outside.
QUESTION: Can the lock be drilled out for access, OR should I call a locksmith?
Recommendations?
Name of a good brain Doctor?
Recommendations?
