TTI early a header ?
MOPARCODY
ROCKLIN, CA
do they make the 1 7/8 race header for the early A?
I decided to stay NA and do a high comp stroker and my hooker super comps are only 1 3/4 with a 2.5 in collector and I think i will benefit from the larger primary/collector size. plus I like the chassis header look better than the 50/50 fenderwell set up
If you want to make the most out of your header you will want a fenderwell header. Tight turns right out of the exhaust port kills power in a big way, more than the little increase in primary tube diameter.
