[WANTED] tubular a arms for a body
john schmid
New Member
ontario canada
Rating - 0%
0   0   0
im looking for a set of upper tubular a arms with the big ball joint for a a-body ..may even consider small joint cause changing brakes to wild wood .i live in canada so may get lucky and a canadian member with something .our dollar is in the tank
Firm Feel makes a small ball joint also.
What bushings are used with these. Are they free floating bronze or steel or press fit standard bushings? Thanks Steve
Honestly, I have no idea.
They appear to use the standard / common aftermerket control arm bushings that you can buy anywhere for about $25.
Looking for a free floating set without rubber for a foot brake car. Most are using hyme ends I would like bronze or aluminum. I will ask my son if he could machine some to fit . I will get back to you Steve. Rubber in the suspension promotes shake and red light on release of brake. I will talk to my son today when he gets home from the shop. Steve
