bigdemo1
- Joined
- Mar 15, 2009
- Messages
- 838
- Reaction score
- 4
Hi,well I got my 360 commando in,(from Mancini's)almost everything checked out fine except the #1 main had the windage tray bolts in it and the fuel pump eccentric cupped washer was backwards(it pays to check everything).Motor is in and running except I think I'll swap out that Torker 2 for a crosswind,anyone have experience with similiar motor setup. Torque converter is M.M.musclecar conv.3:21,1 gears.Seems to ride around on top of cam at low speed only way to describe it,higher stall?steeper gears?probably going to do A518 swap.Don't like that jerky low speed ride.Ideas?
