- Joined
- Jan 8, 2012
- Messages
- 7,098
- Reaction score
- 4,247
Recently brought my 383 back to life after 24 years of silence. I had loosened the rocker shafts and popped the push rods out when it got put away. I did pull the heads and it looked as clean as the day the car was put away. A little oil in the cylinders and re-assembly then 2 more years of waiting on the body.
Never turned the motor again until pre-priming with the distributor out. She fired right off and never made even a slight tick.
I believe having all the valves closed helped keep any moisture out and had to be easier on the springs. I have not turned any rpms above 4k yet but all seems well.
