U joint conversions
Brooks James
VET, CPT, Huey Medevac Pilot
Fruitland Park Fl
I remember there were u jointz that would adapt a 727 yoke large joint to the drive shaft small joint 904
Can't find them !!
Ideas .......
I believe there used to be those available.
I will research it when I get back from Division Final
Monday if nobody has found the number by then
1310 or 7290 or 1350 on the yolk on 727
25-3244X Spicer Select U-Joint Conversion 7260 / 7290
DIMENSIONS
  • Dimension A = Dodge 7260... 2.125 inches (2 1/8 inches)
  • Dimension B = Dodge 7290...2.625 inches (2 5/8 inches)
  • Dimension C = Dodge 7260...1.078 inches
  • Dimension D = Dodge 7290...1.125 inches (1 1/8 inches)
I also believe Moog part number 347
Universal Joint, Detroit 7260 to Detroit 7290 Style Conversion, Greasable, Steel,
