U-joint for a bastard combination
a70duster
Mountains, CO
Hello all, I'm temporarily using a mystery driveshaft. The yoke is for a 727 trans and I'm fitting it to an 8 3/4" rear diff. The length is correct BUT the u-joint caps are too small to correctly fit in the 8 3/4 pinion yoke.
I'd need a u-joint with different cap sizes.
Thanks
More information on the combination universal joints for the 7260 and 7290 sizes:
7260 and 7290 are not part numbers, but are series reference numbers from the Detroit division of Chrysler, for the smaller and larger cross and roller universal joints commonly used in the propeller shaft, or drive shaft, of most rear wheel drive Chrysler passenger cars and light trucks from the late 1950s into the 1990s.
7260 and 7290 Universal Joint Sizing
Dimension measurement information for the 7260 and 7290 universal joints is listed in the following.
The following image shows the sizing at the driveshaft yoke:
7260 and 7290 yoke and universal joint sizing detail:
7260 Distance between retaining ringsG2.125"
7260 Cap Outside DiameterD1.078"
7290 Distance between retaining ringsG2.625"
7290 Cap Outside DiameterD1.125"
7260 and 7290 Combination Universal Joint
To mate yokes of different sizes,a combination universal joint with both 7260 and 7290 dimensions is available.
The combination universal joint yoke dimensions are shown in the following:
7260 Distance between retaining ringsG12.125"
7260 Cap Outside DiameterD11.078"
7290 Distance between retaining ringsG22.625"
7290 Cap Outside DiameterD21.125"
7260/7290 Combination Universal Joints Part Numbers
BrandNumbersNotes
Precision347
Moog347Formerly Precision
Dana Spicer25-3244X
5-3244X (old number)
5-527X (old number)
TRW20226Now Federal Mogul
ACDelco45U0169
GMB240-0369
215-1309
MeritorCP527XFormerly Rockwell
PTCP347
360 (old number)
SKFUJ347
Chicago Rawhide (CR)UJ347Now part of SKF
Neapco2-0527
Mcquay-NorrisU527
Perfect Circle527
RockfordK527
Borg Warner114527
Amgauge114527
Allied Eastern Corporation (AEC)360
Xact-fitXF527
AAP20527
NIKKOG5369X
Neotek20527DL
MotorMaster3133-C
Northern Auto Systems847733
NAPANUJ240-0369
UJ347
P347
GMB240-0369
