Captainkirk
Old School Mopar Warrior
Well, soon enough (I hope) my Duster will be completely treated on the underside with the flat black Rust-Oleum "Rust Reformer"/converter. The question is; what to follow it up with?
First on the auction block- Type of paint. Right now I'm battling between Rust-Oleum enamel and Krylon; both have an excellent reputation, spray well, and leave little in the way of runs, drips or errors., Yes, unfortunately I'll have to use rattle can/spray bomb-type paint....or will I? I suppose I could drag the gun under there. Seems like a waste (and unneccesary expense!) for the bottom of a car that should never see a winter's day. Anyway, I'm open to suggestions based on your own personal experience....good OR bad.....and look forward to your suggestions.
Next up; color! The drive train (differential, springs & shackles, drive shaft & trans will all be Rust-Oleum white. I was gonna do the underside in basic gloss black but I wondered (again) if any of you have tried any unusual colors with unusual results. Pix please, if you got'em!
Last but not least; I've considered doing the entire underside (minus drivetrain) in undercoating, in which case color wouldn't matter. I'm a bit hesitant as the undercoating I sprayed (30 years ago) over primer actually has rust sopts popping through (this after sitting 30 years with little or no road time!) Not a very good commercial plug for undercoating. Of course, had I undercoated over a good enamel, results might be very different. Your experiences, comments, etc? Thanks!!!
