upper CA
OllieDemon45
Mid Michigan
I installed a MBM disc brake kit on my Demon. The kit came with the spindles and have the insert for the small upper ball joint. My question is.. I need to replace my upper control arms because the bushings are too bad, i'm thinking about going with a set of QA-1's with the bigger ball joint. Will these fit correctly if I remove the spacer/insert from the spindle, or do i need to order the arms with the small ball joint.
Thanks
if MBM uses the same ones Dr Diff does, then yes
Mopar A-Body Upper Ball Joint Tapered Adapter
Yes they used the cone for the spacer. So once i remove the cone, that should be the correct size for the bigger ball joint i assume.
looks like the right ones, sway bar shouldn't be affected by the uppers
