Upper Door Panel 73 Duster
SLC Duster Dude
Salt Lake City
I'm trying to find replacement pieces for the upper section of my 73 Duster's door panel. Specifically, the hard plastic part that holds the window felt. I can find plenty of sources for the card portion, but not the top part. Any Ideas?
I don't believe they reproduce the upper door plastics yet.
I have a pair out of a 73 dart if they are the same.
the plastic just did not t ake UV well! some colors last better, all can be vinyl dyed..... yep hard to find and good luck shipping them!
My driver's side has a small crack in it...perhaps it's worth trying to see if I can super glue it together.
If the crack is at the bottom side of it, you might get away with gluing it.
If the crack is at the top it won't hold.
The problem is that they warp curved up on the ends and just mounted on the door stresses them in that same direction as to open the crack and let it continue to travel.
Maybe consider covering them after filling the crack if you can't find replacements?
If you do find used replacements make sure you get pics good enough to see any bow in them, because it's really common on ones I have seen for sale.
