[Found!] Upper kick down rod for a 273 4BBL
68 CUDA FORMULA S
Clarkston Michigan
I have converted my 66 Barracuda 273 904 from the factory 2bbl to a commando 4bbl intake and a Holly 4bbl and I am looking for the upper kick down rod with the slide. First picture is what I have from the 2bbl, and the second and third picture is what I am looking for, fourth picture is just the diagram, looking for # 12. Please let me know what you have.
Thanks
Bob
I am also being told that I can put the entire 68 on up 4bbl kick down set up ( that's whats in the fourth picture, the diagram ) on my 66, so if anyone has this set up please let me know.
Thanks
Bob
I'm pretty sure I've got all the parts. I'll have to do some digging but I'll look.
I modified the one I have for a mid rise manifold so it may be to tall for your application. What manifold are you using?
Edit, I see you just need the one part?
You need the carb stud, the slot and the bent rod, correct?
