Vacuum Hose size for Air Cleaner
340six
King Of Bling
New Orleans
The little hose on bottom of base?
Looks to use same size on 340 4bbl 1972 early 1973 Trap Door and 1973 4bbl.
But what size is it?
The one that connects to the breather? Should be 5/8”
No not that one, i use 5/8 heater hoseon the
Vacuum hose that connects this.
Also I assume they also make this part as a service item. Think it is bad.
The vacuum hose to connect to the air cleaner vacuum pods for the air flaps and the air cleaner temperature sensor is 5/32 inch.
The air cleaner temperature sensor is retained with two push nuts and is replaceable, but not commonly found on the aftermarket. The original Chrysler number is 3514168. Carter and others made replacements. The Carter number is TS10.
Following are other aftermarket replacements, although some might be discontinued:
- Standard Motor Products ATS9
- Airtex 5S1096
- Carquest 71-1542
- Niehoff FE613
- Wells E120
- Echlin 2-2252
