VACUUM OR MECHANICAL
na968
Member
magnolia, ohio
GREETINGS, I HAVE A 1968 BARRACUDA 340S FASTBACK WHICH IVE RECENTLY CONVERTED FROM A TRAILER QUEEN TO A DRIVER. 340, 509
CAM,STOCK COMPRESSION, SINGLE PLANE INTAKE, 750 DBL PMPR, MP
ELECTRONIC IGNITION AUTOMATIC 3800 JW CONVT, 410 GEAR, MT DOTS. RUNS 8:40S 1/8 MILE. THE 750 IS WORN OUT AND IM DEBATING
ON ANOTHER 750 OR THE NEW HOLLEY STREET AVENGER. ANYONE HAVE THOUGHTS ON THIS. I RACE ONCE A WEEK AND MAKE SHORT TRIPS .
THANKS IN ADVANCE .
GARY WELFLEY
With that Cam,Converter and Gear I would use a Double Pumper.
Essentially, a Street Avenger is a double pumper with vacuum secondaries.
THE 750 IS WORN OUT
Get the throttle shafts re-bushed and throw a rebuild kit in it. There's not much else that can wear out.
