Valve Body Cleaner
69signetv8
Sooke BC
Installing a TF-2 :headbang: and would like to know what a recommended good pressurized can of spray cleaner for the valve body would be as the directions say not to use rags for cleaning or wiping. (understandable).
Thanks.....and wish me luck :shaking2:
OH Stay away from lint rags.. .BAD!!!!! get stuck in valves etc...
OK mineral spirits works good, you can use card cleaner, just make sure what ever you use to clean it with you rinse it off good, thn I like to soak all parts in atf when done before it goes back in...
Brake cleaner, no rags. I would only use the blue paper towels for the pan and such. For the valve body itself use just brake cleaner and air dry.
Yes this is good advice, either buy brake clean bulk and one manual pump can, or go buy a few spray cans, you can always use them up. :headbang:
