Question on valve lash, should there be any movement/play in and out on the push rods? I was checking the rockers and noticed some are tight, some I can twist, and some have movement in and out. I can adjust them but not sure if this was normal after a few hundred miles on the new build. I have never set lash before. Any tricks on adjusting with engine in the car?
