green75dart
Member
I have a small block water pump pulley for sale. Great shape, it's 2.17" deep. I needed the deeper one for my setup. $40
Valve springs, 10 degree retainers and locks removed from new speedmaster small block heads. I went with a roller cam and replaced these parts out of the box. Zero run time. $80
Specs are:
Diameter: 1.45"
Max Lift: .600
Coil Bind: .1.060
Intake Install: 145lbs @ 1.9
Exhaust Install: 145lbs @ 1.9
Closed Seat Pressure: 145lbs
Open Seat Pressure: 360lbs
Specs are:
Diameter: 1.45"
Max Lift: .600
Coil Bind: .1.060
