Valve springs-can i run?
sabre67
B.C. Canada
I have Edelbrock RPM heads for BB, they have dual valve springs with a 1.550 OD. My question can I run my Lunati dual valve springs which are 1.450 OD on these eddy heads? Thanks
If they clear the guides and oil seals with the ID, sure. Use some sort of locator to protect the soft aluminum from the springs eating them up. S/F....Ken M
333 lbs./in. spring rate 268 Lunati cam 494/513 lift@50
Lunati # 73100-16 kit 6 is the spring kit,dual springs,retainers,and locks complete kit. Yes that is my cam and heads,i wanted to use the spring kit on the eddy heads. all parts are new
