Sep 20, 2010 #1 7 74valiant Well-Known Member Joined Mar 4, 2008 Messages 423 Reaction score 2 Location THE D theres a 76 or 78 volare wagon with disc brakes on it by me. i was wondering whether they will work on a bodies??
Sep 20, 2010 #2 friesza The Machinist Joined Dec 22, 2009 Messages 971 Reaction score 2 Location Sweet Home, Or That is the swap I am doing now....depending on the year of your a body car you will need the larger upper ball joint control arms from another a body...do not use the Volare control arms...get everything you can....check out this link... http://www.bigblockdart.com/techpages/spindles.shtml and this... http://www.bigblockdart.com/techpages/dbconversion.shtml This should tell you everything you need to know.
Sep 21, 2010 #3 C crackedback FABO Gold Member FABO Gold Member Joined Aug 7, 2005 Messages 20,329 Reaction score 8,501 Location 92201 Works fine. Your car, if the one in your sig, should have large ball joint uppers. Easy swap for you.
Oct 5, 2010 #4 dragdak Well-Known Member Joined Jul 18, 2007 Messages 380 Reaction score 12 Location minnesota Remember you will need the caster correction upper arm bushings. I got mine from ORIELEYS. Cheap too.
