71dartswinger
FOR SALE VW SANDRAIL PRO-TECH KIT. FRAME SANDBLASTED AND PAINTED
A COLOR THAT IS ALMOST SUBLIME GREEN. THIS RAIL IS DISASSEMBLED AND
NEEDS CARBS INTAKES BRAKES/LINES/MASTER CYL WIRING HARNESS(HAVE
HARNESS FROM 62 BUG) 62 SWING REAR AXLE.TWO VW RIMS FOR FRONT. THE GOOD STUFF--
MOTOR IS 2180CC ,82MM STROKER CRANK, 92MM PISTONS, ALL MACHINE WORK ON BLOCK DONE CB PERFORMANCE OVAL PORT HEADS COST $900.00,
ALL NEW BEARINGS FOR MOTOR , FK10 CAM, NEW ROCKER ARMS. THE ONLY PARTS IN MOTOR THAT ARE USED ARE BLOCK,PISTONS AND JUGS.
ASKING PRICE IS $1500.00
STEVE 863-307-4908
mopardart71@yahoo.com
STEVE 863-307-4908
