[FOR SALE] W2 Head(s)
CMcAllister
South Central PA
WTS - W2 head. This is a pair of early 3670809 open chamber W2 heads. Sadly, one of them has a crack running across the lower head bolt area. It looks like it may have been tightened down over a dowel pin too long or similar situation. Then was epoxied in an attempt to fix it. Heads are ported and have valves. Has not been cleaned or checked. Sale is for one. Take the other if you want it. $300 OBO. Prefer not to ship but we can discuss that. Located in 17267 South Central PA.
No. It is a crack that runs most of the length of the head, just above the lower head bolt bosses. Someone tried to repair it which is what the gray epoxy is.
Okay. Is it visible from the bottom like it cracked all the way trhough
No. I haven't done a dye crack check or ground the epoxy off to look at it either. It just looks like a crack running across the head in a couple of spots. I don't want to say the head is salvageable or repairable without confirming it for myself.
I don't anticipate going to Carlisle, except to maybe spectate Friday. If you are driving in from Iowa, you'll be driving within a half hour of me, depending on your route.
