[FOR SALE] W2/W5 Rocker Arm Shafts - New
Rocket
CT
I have a couple sets of new W2/W5 shafts. These shafts are made here in the U.S. and are chromoly and hard chromed. They feature banana groves and 3 oiling holes per rocker arm (one in the banana groove on the load side, one for the pushrod cup oiling and one to oil the valve tip/rocker pad. These shafts are made of thick chromoly tubing to resist flexing for high spring pressures and are much thicker than stock Mopar shafts (see comparison photo). These are offset drilled for the hold down bolts are for use with offset drilled shaft blocks. These will not work for the W2 econo heads with pedestals. The end plugs are screw in to allow easy cleaning, inspection or oil feed lines if you are not using oiling through the block deck.
Price is $300 shipped for the pair within the lower 48 states.
PM me for more information.
