[WANTED] wanted big block rocker arms
Darren what style rockers? standard, adjustable, roller? I'd imagine a parts warehouse should have the stock stamped rockers in-stock..
Just a thought Darren, If the two rockers need replacing because they're worn out in the area where the rocker shaft goes through or the area of the rocker where the push rod contacts is worn out or worn through I'm guessing all the rockers are worn and need replacing. Now if you lost 2 of the rockers then that's different. :burnout:
Terry
i have one rocker that when i turn the engine over manualy (engine out of car) the pushrod ball end lightly snaps back end forth in the rocker.
