Wanted: D4B
R3dplanet
Rating - 0%
0   0   0
Right. I'm looking for an Edelbrock D4B intake for my 1965 Barracuda. I'm not interested in machining another intake for the proper bolt angle and fit.
Thanks!
Hot. I'd love to see some pictures. Where in Washington are you?
Here's a picture, let me know if you want it. Stan
If the OP doesn't want your intake. I'll take it. been looking for an LB4B for a 318.
Fantastic. I'm not sure its going to work for me though. What you've got is clearly an LD4B, which I believe has a different mounting bolt angle and diameter for the later LA engines, 1966 and later.
I'm pretty sure the D4B is for the 1964-65 LA engine.
Having said that, if the ports all line up and are the same size I'll happily take it and have it machined. Can anyone chime in and answer authoritatively?
-marcus
Sorry it isn't what your looking for spankmeister, I wonder if the L means it's for a LA block? I'll PM crackedback and see if he still wants it. Thanks for looking though!
I think the "L" might stand for "Late".
D4B for 64-65 273 engines.
LD4B is the same manifold with the revised bolt angle for 66 & later engines with 273/318 sized ports on the heads.
LD340 for the engines with 340/360 sized ports.
If anybody's interested I have an Offenhauser 360 Equa-Flow for the early heads, but it's a single plane.
Got this out of my storage today.
I may be interested in working a trade of sorts. Spamkmeister PM me if you might want to do a bit of a swap. I have over $100 in the D4B intake.
