Wanted: V8 Center Steering Link for 72 Dart
SwingerDeluxe
Rating - 0%
0   0   0
I did a /6 to 318 swap. Have a slight rubbing on headers from /6 center link. Need a V8 Center Steering link for 1972 Dart Swinger. Not sure what years would interchange.
Which headers do you have? Which mounts did you use? I ask these questions because there is no difference between the slant 6 and V8 center links from '67 to '76. '63-'66 were the only A bodies that used different center links for slants and V8s and that was for oil pan clearance. If you are having clearance issues with the headers, the problem lies in the headers unless they are TTIs.
You don't need a center link swap on your car.
The engine may not be in the proper location which makes any header fit wrong. There are fairly large variances in the building of these cars. The tti site may have the measurements for where the engine should be located.
Saggy, tired engine rubber mounts cause problems here too.
