AlaskaJeff
Or do you have to swap out everything to get the bbp?
in a word, yes.Or do you have to swap out everything to get the bbp? View attachment 1716402344
Thanks for the reply. That's pretty much what I did in the rear with the 11" drums. My Duster currently has 1" spacer/adapters on the front converting sbp to bbp, NOT ideal but it works for the time being. Ultimately I want to do a disc conversion up front. But that's going to be down the road a bit.in a word, yes.
but it depends on what you have and what you're trying to do.
if you can find a competent machine shop you can drill the hub and drum for BBP if that's what you're after. otherwise there's no BBP front drums for a-bodies.
